FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Alright, I've read some conflicting things about high-speed & low-speed needles.
My motor starts up great and runs in the barrel with the throttle at the START position - but sneezes and dies when I try to move the throttle to SLOW.
Which is which?
I believe the needle with the large dial on top is the high-speed? Then the L-shaped needle on the front of the engine block is the low-speed?
Do I have this right?
yes you are correct, the L shaped needle is the low speed . generic setting should be 3/4 turn out from lightly seated. ( they can be very sensitive, so make small adjustments and give it a few seconds to react)
Yea as both stated, 3/4 turn out is the starting point for adjustment, but usually, if not always, find that the TN ends up being about 5/8 of a turn out by the time Im done.
If it is still lean sneezing we will have to dig deeper
