Hydrolocked 4.3 Options
bruceb58
Just so you know, Mercruiser doesn't make them.....GM does.
Made in either the GM Romulus or Tonawanda engine plant. Same plants that supply GM trucks.
Why spend $130 for a used piston and con rod on ebay when new from GM its about $60
For $800 you can get new rotating kits with better pistons and forged rods, or for $300 you can get a pull out motor from LKQ
You just cant take a piston from one motor and drop it into the bore of another motor and hope it to work. You need to measure, at least hone, and install new rings
atv_freak
I realize I'll need new rings. But just replacing the piston is a feasible option isn't it?
I'm trying to do this as cheaply as possible, so $800 right now isn't an option.
If the bore after a deglazing hone is still in spec for the piston and rings, then yes. If not, than no.
As i stated, a running long block is only 300. You still need gaskets. Brass core plugs, etc. So your into it for 500. A good short block is less and you can use your heads.
