hydrofoils
walla2
are hydro foils worth it and witch one do you recommend. i have a 18.5 foot reinell with a 4.3 and an alpha one outdrive.
achris
More fish than mountain goat
Re: hydrofoils
ONLY if the engine installation is slightly higher than 'normal'. If the engine installation is at the standard height, a 'wing' will cause high speed handling issues.
Chris.......
chriscraft254
Re: hydrofoils
If you haven't looked into them already, look into Nauticus Smart Tabs. They will perform better than any hydrofoil and they don't cost much more than a hydrofoil. Imo, hydrofoils are not worth buying.
walla2
Re: hydrofoils
if you haven't looked into them already, look into nauticus smart tabs. They will perform better than any hydrofoil and they don't cost much more than a hydrofoil. Imo, hydrofoils are not worth buying.
thanks i will check into them
walla2
Re: hydrofoils
hydrofoils or tabs? Big difference.
i mainly use my boat for pulling tubes and just cruising. Are you saying there is a big difference between the two or that either one will make a big difference. Thanks
Re: hydrofoils
Ayuh,.... Either 1 will make a Big difference......
Smart tabs work Great,....
Whaletails usually end up bustin' off the cav-plate, from the drive housin'....
