Hurricane SD187 Windshield Removal
Thfrazer
Hi,
I'd like to permanently remove the windshield on my SD187. Can this be done and how hard is it? How many holes will be left after doing this? Is there anything I can put in those holes? Do I need to?
Thanks in advance for your feedback.
Tom
rdcastle
Re: Hurricane SD187 Windshield Removal
Hi,
Tom
Tom,
Unless windshields have changed drastically in the past few years, there should be a rubber strip set into the bottom aluminum channel of your windshield. If so, pull it out to expose the screw heads that secure the windshield to the fiberglass. I recommend that you fill all the holes with some thickened epoxy and finish it off with some matching gelcoat. I discovered this because my windshield on an older Rinker bow rider came loose once and I saw the corner of the rubber stip sticking out and pulled it out. Tightened the screws and it has been fine since.
