Hull Repair
chiefraz
what is the resin used to make the hull of a 1998 Sprint boat. Have repairs to make. Its either SMC or polyester
BigLee324
Re: Hull Repair
send a private msg to Opps, he can help you.
chiefraz
Re: Hull Repair
yes it is FG, just trying to figure which type was used so proper repair can be made.
Bob_VT
Re: Hull Repair
Welcome aboard.
Use regular Non-waxed fiberglass resin for your repair and you will be fine. Do not be tempted by the off the shelf Bondo products.
Woodonglass
Re: Hull Repair
Your boat is made from Standard Polyester Resin. You should use Standard Laminating Non Waxed Polyester resin like the 435 resin sold by uscomposites.
