ricardo.benin
- Mar 20, 2014
- 6
Hi I have a 95 maxum it is a bow rider and it has a 120hp force outboard any ways on the port side rear quarter underneath the rear side seat were the little door is that the battery is behind there is a rotten section of the hull that needs to be repaired anyways just tore up carpet and found this, basically I tore out every thing that is missing in pics any suggestions on how to fi the deck. The foam is retaining water so should I put a space heater in the boat for a while to make sure everything is dried out. The rot came from the battery door hinge that had 4 screws going into deck to hold hinge in place as well as a hole that maxum put in the floor to fill hull with foam. BTW the pics look a lot worse then it actually is and the rot is not on any major supports beside the one in pic that goes to front and back of hull, the support that goes to front and back of hull is unharmed by rot and should be ok.
Thanks
Thanks
