rfdfirecaptain
Thread starter- Joined
- Aug 17, 2008
- 314
While restriping my boat yesterday? after a few weeks worth of a compounding and buffing job, I noticed a problem on the bottom of my hull. About a foot inside my Starboard stern corner I noticed a small bulge or "puffy" spot in the bottom paint a little smaller than a baseball. The bulge is raised no more than a quarter inch. It?s covered with bottom paint so I don?t have a good visual without doing a lot of sanding.
Anyway, I tapped and pressed all around the bulge. The puffy area was spongy. Not so spongy that my finger would push through, but soft enough that I could see it flexing. Other areas toward the stern, gunnel wall and keel were solid and hollow, where it seemed appropriate as compared to the Port side of the boat.
I would like to make the repair from the outside. Actually, there is no other option for me. I would have to dismantle too many things to get to it from the inside.
I just read in another thread http://forums.iboats.com/showthread.php?p=2971091 about an epoxy repair. So, assuming that is the method I will use, here are a few questions:
1. What the largest size hole I can repair using the suggested epoxy method?
2. Would it be advisable to use a hole saw to cut out the damaged hull area? It would certainly make a cleaner and neater hole and probably a more stable area to work within. Thoughts?
3. If a round hole is advised for this repair what would be the largest diameter that the epoxy repair could be trusted to repair? I'm thinking I may have to go anywhere between 1.5 and 3 inches.
4. In the thread linked above Mark42 suggested using ?small pieces of csm?. What is ?CSM??
Is epoxy the only way to repair? Can anyone suggest other ideas or a well established thread with detailed repair information? Thanks!!!
