Re: Hull repair help needed
i would just use a structural thickened resin.
25% resin
30% 1/4 inch short strand
45 % milled fibers...(powder)
catylize the un waxed resin first at 1.5%. then mix in the fillers to the catylized resin....mix well.
spread the filler into the prepped and cleaned area..
make sure to gish the filler into the exposed area.....really push it into the hole.
use the thick filler to make the shape of the chine or strake.
glass the wet layer with 2 layers of 1.5 csm.
let partially cure untill most of the heat is gone form the theromlitic reaction.
glass with another 2 layers of csm. each layer lagrer than the last.
let go to full cure.......
sand and fair.......apply gellcoat sand , fair, polish.
this is a standard repair and can be done in 4 hours including cure times.
cheers
oops
Ok couple questions here:
1. does each and every layer of CSM have to be progressively bigger or just the final 2? and how much bigger say a half inch past the edges of the previous layer or an inch or 2 inches?
2. Can I add a layer of 1708 biaxle after the first 2 layers of csm? - I ordered it just incase and seeing the damage I'd feel better knowing I added it.
3. Do I need to mix wax into the resin for the last 2 layers of CSM so that I can sand before gel-coating?
4. How many layers of Gelcoat is recommended? Do I have to fully cure or sand between coatings? and should I add wax to all coatings or only the final?
Sorry for all the questions. And thanks again for all the help you guys have been.
