So I am new to the site and the forums have been a ton of help.
I had some leakage last year and started to find rotten stringers, so two days later I have gutted the entire hull and removed all of the water logged foam. I am starting to get the to dirty work of grinding everything down so I can rebuild.
But I am thinking about the next step and the best way to rebuild the stringers, and everything I have seen so far everyone rebuilds the stringers with plywood and applies fiberglass over them to seal them from water.
I am wondering why not use 3/4" thk. PVC sheeting instead of plywood and then having to seal it? PVC will never rot is this not a better alternative and one less step, not having to seal it like plywood? Are there structural issues with PVC vs Plywood?
Any thoughts on this would be great? By the way this is my first re-build so this maybe a dumb question, I could not find anything else related to the subject.
Thanks
jim
Thanks
jim
