ihopeitfloats
- Oct 15, 2012
- 14
I recently bought a 1978 Sportcraft and am going to paint her before she goes in the water next spring. The previous two owners did a crap job painting the hull, and I'd like to do a proper job.
The POs seemed to just glop on layer after layer of paint, and some layers peeled away, giving the paint a weird, ugly, layered look (please see pictures). The third pic shows where paint chipped away to what seems to be the bare fiberglass base.
Can I use a sander to sand away these paint layers? If so, once I get it down to the fiberglass, what sort of primer should I use? After priming, can I then just apply the first layer of antifouling paint, or does there need to be a layer of something else between primer and antifouler?
Are all antifouling paints created equal? Do I need to spend an eye-watering amount on that, or will a just-slightly-nauseating amount be sufficient?
One last question: I would like to perhaps change the trim color from maroon to royal blue. I see from previous threads that Simply Spray seems to be the go-to brand for changing bimini color, but will I get a weird dark color if I try to put royal blue Simply Spray on top of maroon bimini fabric?
Thanks for any help you can offer.
DJ in NY
DJ in NY
