HUGE trouble with Laptop
dolluper
Well the BIL doesn't look so bad now as "I" made a worst mess of the laptop.I was uninstalling a antivirus program amongest others in order to install a better one,when I'm sure the trojan the was in the vault got out
So this is how it goes now I start the computer,windows loads then when it's about to show the next screen LOG in it never appears all I get is ERROR Isass.exe...entry point not found ,entry point Iswellknown Sid advapi32.dll
click that off error 128 Isass.exe C/windows/system32/Isass.exe windows will shut down and restart
Same thing over and over even in safe mode
Tried bootable disc same results
Harddrive time or any suggestions would sure help thanks if you can help :%:%
Plainsman
Re: HUGE trouble with Laptop
Is it XP? If so, when starting the computer, before windows starts, press the F8 key. Then choose Last Known good configuration.
dolluper
Nope 2000Pro Dell lap......Last best known configr=same error F2 >>>>change year=same error
F12 to boot =same error
F2.>>> change boot order =same error
now I'm even using F in my language
Plainsman
Changing things in the BIOS won't help I'm afraid. Do you have the 2000 CD? If so you can boot to it, go through it like your going to reinstall windows.
You'll come to a screen that asks you if you want to repair or do a install. Choose repair and a dos screen should come up. It asks which install you want to repair, type the #1. It will ask for a password, type it in.
Then type chkdsk /? this will give you a list of switches to use. I think it's chkdsk /F
HTH,
Eric
imported_Curmudgeon
Go to Ebay, bite the bullet and get an XP upgrade. 2000 sucks and will probably become unsupported when Vista gets vetted. While you're at it, get Norton AntiVirus and keep it current. Do it now or do it later, your choice... :love:
dolluper
Hay Curmudgeon U got one cheap!:devil:eek::)o:)
roscoe
Better yet, go to ebay and buy an Intel MacBook
Run OS X most of the time, and switch to XP only when needed for "special" software.
BoatBuoy
I have to take issue with this statement. Before I retired, we had 33 large MS Exchange servers, 43 Domain Controllers running Active Directory, and an untold number of file and print servers, all running Windows 2000 and servicing 13,000 employees over 7 states and DC. 2000 only sucks if you don't know anything about it.
BTW, roscoe, try doing all that with OSX. It's not a panacea.
Xcusme
Ditto.....and Win2K will be viable until January 2010. As for Norton Antivirus...have a look around. Symantec is having a really bad time with NAV. There are much better options.
SpinnerBait_Nut
dolluper, just went thru the same thing with my back up desktop.
It would boot up to my desk top and then kick off and do it all over again, even in safe mode.
Mine turned out to be a bad processor.
Don't know about your's, but sure sounds like the same thing mine ws doing.
i386
Congratulations on your retirement. Exchange was written by the devil himself.
I'd really like to see the innards of an AD structure on a domain that size. My fave customer has about 50 computers and 9 servers. One of which is the DC. I've implemented group policy for them ( <3 gpmc ) throughout all their departments. We can now just about plug anything in anywhere, drag it into the appropriate OU, gpupdate, reboot and let it go.
It would be interesting to see how it all scales up across multiple sites and all the other neat stuff that comes with it.
For as much as I like Linux and hate Microsoft sometimes, I don't know of any solution that touches AD. (Novell might, but it's mostly alien technology to me.)
Gary H NC
Will installing XP over the older OS get rid of the virus?
I have tried that and had no luck.
I ended up re-format then fresh install..
I have a XP corporate edition that i could make you a copy of but i won't be home for 2 weeks to do it..
roscoe
I never said OS X was.
Expecting OS X to run a 2000 system would be like trying to run a Merc I6 with an ECM from a n Evinrude V4. Two different animals.
What I said was with the right laptop (Intel MacBook) you can run OS X AND Windows XP when needed, on the same computer, without even rebooting. Switching between the two as needed.
Why not have the best of both worlds.
If he is to even consider a new laptop, there is no logical reason to not consider a MacBook.
dolluper
Nope I'm gonna fix this old anchor,got a Dell reinstall CD coming from a buddy,fresh never been used and use my code from mine. Only problem is it has SP1 so a little work to get her back up to snuff.Found a nice utility on micro's site for installing mutible hotfixes without rebooting for each one,yes for 2000 some of the stuff they are cutting out June 30 th this year
BoatBuoy
On June 30, 2005, the Windows 2000 product family enters the Extended Support phase, which continues for at least 5 years through June 2010.
• Microsoft offers a minimum of 10 years' support (5 years Mainstream plus 5 years Extended) for business and developer products. The Microsoft support life-cycle policy provides predictable coverage of Microsoft products and continues to set the standard for product support policies industry-wide.
• Microsoft is not ending support for Windows 2000. During the Extended Support phase, Microsoft continues to provide security hot fixes and paid support but no longer provides complimentary support options, design change requests, and non-security hotfixes.*
Note: The Update Rollup for Windows 2000 Service Pack 4 (SP4) is the final release of Windows 2000.
http://www.microsoft.com/windows2000/server/evaluation/news/bulletins/extendedsupport.mspx
dolluper
That's great eh! stability hotfixes end June 30 this year but you will have the security ones till 2010
Gary H NC
Not sure your old serial key will work with the new cd.
Let us know if it does.Just curious...8)
