maineiac5586
Master Chief Petty Officer
- Feb 14, 2009
- 824
Had a bearing go bad on my loadrite single axle roller boat trailer. I got a whole pre assembled hub at tractor supply but want to make sure the weight rating is OK. Box with the tractor supply hub says 1,750 lb capacity and the label on the trailer is attached below. Advertisement for my original hub shows 1,875 lb hub rating. Label on trailer tongue Shows gawr 2995 lb all axles . Does that mean 1497 lb per hub? If so I guess I'm fine. Just making sure.
