Hub man question!
surfin_sarah
Can a prop shop determine quickly whether you have a spun hub or not!:(
My prop come off of a 60 merc outboard about 1998 model, the prop is off the boat, i see no rubber bushin in slide like my orginal prop. Boat only goes about 3mph before the engine reves up with no movement.:cool: (made for a long drive in):rolleyes:
Re: Hub man question!
Check it yourself. Using a marker, place a dot on the hub of the prop. Then place another dot on the blade area directly in line with the first dot. Run the motor until the problem occurs. Check the marks. If they are no longer lined up, its slipping. If they are lined up, its not.
