Hub kit or no hub kit?
watchinthebobber
What is preferred? Is the function of the hub kit just to protect the drive shaft in case you hit something? If you had a choice to purchase a prop with or without the hub kit what would you choose?
Thanks
scipper77
Re: Hub kit or no hub kit?
If you ever have to replace a prop with a hub kit you will save a little bit of $$ not having to buy a new hub kit! Of course the initial purchase of the prop plus hub kit is more than a prop with an integrated hub.
If it's an aluminum prop the prop should break before your lower unit (note the word "should"). for a stainless prop it's another story.
watchinthebobber
Ok, so if I'm using an aluminum prop then I shouldn't really worry about buying a replacement prop with a hub kit?
Silvertip
Honorary Supreme Mariner
Neither! What you should worry about is finding the prop that allows the engine to perform as it should. If that prop has a hub kit, fine. If it's a fixed hub fine! Why buy a prop that may not perform as well as a fixed hub prop just for that feature (and the opposite applies as well).
