However
barnyard
After much work on boat that was supposed to be done during winter I finally put it in water. However I did not connect( Alpha 1 gen2) small tube on frt of outdrive that connects to lower unit. Boat is in water. made short checkout trip approx. 10 minutes. What should I do?
Alumarine
Is this a plastic tube about 1/4" in diameter?
If so, that's probably for the speedometer. No biggie.
Ayuh,.... Like Marc says, it's the pitot tube for the speedo, no big deal,...
Rick Stephens
Next time you go swimming, tilt the drive all the way up. You can reach in and hook it up. Won't hurt anything except the speedo won't work until then.
