how would you recommend repairing this hull
slasmith1
Re: how would you recommend repairing this hull
I can't see what the structural side looks like so here goes for my 2 cents.
First go to town with this tool:
Then place the smaller peices in this recepticle.
Ayuh,.... She looks pretty rough,+ Broken,.... Pretty well Stripped too....
Shouldn't take more than 20/ 40 Grand to turn it back into a RocketShip....
If ya do All the work Yourself of course....
legoman67
i agree, if its not too late i would stay away, it would be a ton of work just to make it float again, no matter look good.. plus i dont see much else there other then the broken hull. there are better deals out there! also if its hurricane leftovers odds are all the support inside is toast now too...
GRANGER65
no it's not stripped at all. it is a 10 hour baja hammer that is almost new but was side swiped by another boat it is completely there
legoman67
maybe afew close ups would help, hard to tell the extent of the damage from the one pic...
GRANGER65
a couple more photos of damage
legoman67
can you get to the damaged area from the inside? looking at that second pic it looks as if the entire hull is caved in, if that is the case, unless you can part it out i would continue to run.
boat1010
Did it sink after it was hit? Sure looks like a lot of work to me!!!
GRANGER65
yes i can get to it from inside. part is not really caved in, but is in a bind because when t
]he 2 boats sideswiped the screws around the rail pulled out and the hull and deck are in a bind. i think when i pull the trim and screws out, it will sit back in place. the boat holds water and does not leak. the are no holes below waterline or really anywhere, but i can se the fiber mat where the gelcoat once was
slasmith1
I would bet that an insurance company totaled it because it will cost way more to fix than the boat is worth. Even if you can make it look right you will still most likely have problems with a hook in the hull.
ebry710
Ensign
That is some damage. I guess you have to just fix it one step at a time. I think it would overwhelm me......then I would start fixing it. Good Luck.
I wouldn't mind seeing updates on this repair.
GRANGER65
ok let me give you an update. i finaly got all the bent screws and rivets out of the rub rail. it was a real pain. i took it off from the nose to the middle of the stern rocked the deck. we kinda rocked the deck and it all kinda fell in place. it was kinda kinked up in one spot about halfway down the side but it almost completely straightened out by itself. i did the coin test around the damaged ares and cutaway the the hanging material around the bottom runners. it all seems prety solid. on the sides as well it seems as if the gelcoat was just knocked off or loose in spots. so i cut and sanded aroind the damaged areas. it all seems pretty solid. can i just re-gelcoat those spots? also on the front bottom on the runner, how do i repair that? it seems really solid and appears to not take on water. do i just re-fiberglass the dameged area?
legoman67
yup, you can spray our brush gellcoat on.. the tone's may not match perfectly, but its better then nothing. spraying will make it more even and smooth.
is there wood showing through on the chime area? if so then grind the gellcoat off around it(be generous give it atleast 5 inches all the way around the damage, assuming its still water tight, if its not give it about a foot all the way around and overlap afew layers of glass) cover it in a layer of glass, just a mat followed by a roven or cloth. or you can use a biax like 1708. and you wont need the mat. let er harden overnight, then you can sand it smooth and appy gellcoat to that aswell.
if there isnt any wood showing, then i would just clean it up abit and apply a coat of gellcoat.
lowkee
I'd love to see a before and after on this one. From the photo, it looks as though it has been left outside (uncovered) for quite some time. How old is the boat? Can you see below deck to see if the stringers are still okay? If they are bent, you are risking some quick rot (assuming they are wooden).
I suppose getting it straight will be the 1st task. One step at a time, go slowly, plan ahead, and you may be on the water causing serious noise pollution before you know it.
redfury
I think at the very least I'd want to take the interior out on the damaged side and run at least one layer of 1708 biax on the inside once the hull was straightened out...that needs to be glassed somewhere because that glass is broken..a little gel coat and a thin layer of glass isn't going to fix it other than cosmetically....it took some force to crack that up.
Robert D
I think I'd go a bit further than one layer of 1708 and a bit further than 5 inches. I see stripping the interior, and completely checking the entire hull out, reinforcing everywhere the factory didn't. This hull has had quite a jolt. It's difficult to say how far the microscopic fractures you can't see go. In time, they are likely to show if you just do a patch job. How fast can you run from it? If too late, I'd cover the entire inside of the hull with 1708 and a bit more. When you feel it has enough to withstand anything, it's probably in good shape. Probably totalled because the labor costs are more than it's worth. But your labor is free, right? :) Have fun....
drewmitch44
That thing is DONE! It is going to cost more than 3 of those boats are worth to fix it. DONE!
DONE!!!!!!!!!!!!!!!!!!!!!!!!!!
Cut it up and scrap it for what its worth and maybee sell whats sellable off of it!
DONE!!!!!!!!!
