How to winterize a non-running 25HP outboard
Savudajo
I have a 1989 Johnson 25HP outboard J25ELCEB that is currently not running. I won't have time to fix it before winter and don't want to add a frozen/cracked motor to the list of issues next spring. In past I have winterized it with antifreeze through ear muffs, but that isn't possible now. Is there a way the blow the water out of the motor with a compressor? Maybe remove the lower end and blow up the water tube? I don't want to damage anything (thermostat?), but want to drain it well. Any thoughts? Thanks.
ThomW
So with outboard motors, you don't actually need to run anti-freeze through the motor. The way outboards are designed, the water all drains out f the motor when it is stored in an upright position. The reason you do that for I/O's is because the water stays in the engine block and exhaust manifolds, and if it freezes, it can crack the block or blow out a frost plug. If you leave the motor in a vertical position for a bit, all the water will be gone from the motor and you'll have no problems. I worked in a shop for many years in Northeastern New York--it gets cold up here--and we would only run anti-freeze in outboards if the owner insisted. It really doesn't do anything, as the anti-freeze runs out as soon as the motor is vertical again.
That being said, take out the spark plugs and spray some fogging oil in each cylinder, then turn the flywheel by hand and spray some more in each cylinder to coat the pistons and prevent any rusting. Then, when your ready to fix it up, get her running, change the gear lube, and start it up. It'll smoke a bit from the fogging oil. After you run the fogging oil out of the motor, you can swap in new spark plugs if you want. If it'll be stored outside, I also highly recommend placing some shrink wrap tape, or similar tape over the end of the prop, as you do not want any snow/water to seep into the prop seal area and freeze. that can ruin your prop seals and cause a lower unit leak. Cheap insurance.
Just my thoughts.
flyingscott
Change the gear lube right away also. If any water in there it will freeze and wreck something even if you store it indoors change it. For the price of those lowers it is cheap insurance.
ThomW
Good point about gear lube Flyingscott!, I wasn't thinking that it may be milky and/or have water in it. Change the gear lube before storage and it'll be done when you finally get ready to fix er' up.
jimmbo
Spraying fogging oil in the cylinders really doesn't do much except coat the cylinder walls. The crankshaft, connecting rod, and piston pin bearings need a coating of oil to prevent rusting. Cranking the engine while spraying the oil in the carb might help, but won't be as effective as having the engine running.
Water drains out of the motor when it is vertical, a few pulls on the starter rope will drain what's left in the water pump/pipe
Savudajo
ThomW, Flyingscott, Jimmbo- Thank you all for the advice. Looking forward to getting her running again in the spring!
