How to test run '93 6HP?
gporter
Is there a flush/test connection for a hose that I can't see?The only water inlet I see is on leading edge of lower exhaust - doesn't look amenable to muffs etc
oldcatamount
Re: How to test run '93 6HP?
Take a large garbage can and fill it at least half full. Hang the motor on it (making sure the water is above the cavitation plate) and you can run the motor at idle speed. Water muffs won't work on your motor.
gporter
Thanks Master Chief - thought maybe - off to the Depot for a metal trash can!
wilde1j
The company that made flushettes for motors like yours called it quits a few years ago (Tempo Products).
gporter
Update:
Bot motor for $250 yard sale; now runs fine in tub; will check on Lake Champlain's record flood this weekend
oldcatamount
Lake Champlain?!! Them's my stompin' grounds!! Be carefull out there, lot's of flotsum because of the flooding!
