jbjennings
Thread starter- Joined
- Jul 18, 2007
- 3,903
Howdy fellers,
It's been a while since I've been on the merc forum. I've got a '73 merc 65hp that's still going strong with jbweld holding the water jackets together after probably 15 6 gallon tanks of gas. I've got myself another boat/motor/trailer cheap with a '75 merc 65hp on it to take it's place though, and hopefully have enough parts to keep this one running for a long time. I've got it running but while replacing the battery cables and repairing the wiring harness, I've boogered up the rectifier on the "newest" motor. I'm going to take the rectifier off my pontoon barge 65hp and use it momentarily. However, I don't think the motor on the barge is charging.
QUESTION: How do I check the rectifier?
How do I check to see if the charging circuit is working?
Also, I just wanted to mention that my newest merc has 150psi on the middle and bottom cylinders and 145 on top. I'm really happy about the compressioin #'s. I've had it running and it sounds good, but am replacing the wiring and am going to rebuild the carbs just in case they're dirty
. This motor hasn't been used very much at all in the last 10 or 15 years. The impeller is working good, and there's an old one on the splash well so I'm going to test it out before tearing the lower unit off to check the impellers since it's working good and I don't think it's that old of an impeller. The oil in the lower unit is black but no water. I'm very pleased so far since it wasn't running when I bought the old boat and therefore got a good deal on it. I had in running good in about 10 minutes--it was missing a fuel pump bolt and the fuel was a little stale.
Thanks,
JBJ
Thanks,
JBJ
