how to tell if the water pump is working
rusty1969
OK, so I have a 1969 40 HP elec shift evinrude. I bought a seloc manual. I replaced the impeller. Now, how can I tell if it is working well? I tested the motor in a trash can of water, ran fine, but where do I look to see if water is flowing well. Small droplets come from a rubber looking hose on the back the unit, just below the motor. Where is the intake? Where is the outlet? Sorry in advance for the simple/dumb questions. Thanks!
oldboat1
Re: how to tell if the water pump is working
You might get periodic spray from the port on the back of the leg, but if it's like my '70 85 was, it's not a tell-tale. If the water is pumping to the head, and the thermostat is working, the head (top around the t.stat) will be hot enough that you will pull your hand away in a few seconds, but not so hot that you burn yourself. That would mean that it's running at around 130 or 140 degrees at idle, which should be fine.
rusty1969
ok, so where is the intake and output? thanks
