How to start a 70's Merc 165
paparoof
Can I use this same method to start my 1975 Merc 165 without hooking up the wiring harness and ignition switch? Specifically wondering if the pin-configuration on the plug is the same as in this video.
http://www.youtube.com/watch?v=NUoXFIo2Ab8
86 century
Ensign
Re: How to start a 70's Merc 165
It's real easy to do with a points system all you need is power to the coil and starter. I would not mess with the plug.
Quote:
Originally Posted by 86 century
...all you need is power to the coil and starter.
And where's THAT video?
Ayuh,... This is a forum, By Mechanics, for Mechanics....
We all know where/ what the coil, 'n starter are....
If You Don't,... You're Way over your head....
paparoof
I know where the coil and starter are, I'm asking for specifics (like the video above) showing exactly where to apply power/ground to start it like 86 Century suggested above.
I just don't have the wiring harness fixed and in yet, so I wanna know the simplest way of starting the motor without the harness and ignition switch.
Is there actually a problem with doing it like shown in the video, or is it just that there's an easier way?
kilowatts
Hi Guys:
Please see the video in my signature. If you freeze frame when required you should be able to figure it out. You'll need a cheap switch to make it work. You asked for a video!
kilowatts
lonemust
If you have ever "hot wired" an older(pre-hei) car under the hood you can do your boat. It's the done the same way.
Fishermark
Here's a wiring diagram:
And here is a handy thing Don S posted awhile back... (which I still think should be in the "sticky" at the top of the page!):
