How to replace the fin above the prop.
Fordiesel69
On my bayliner this fin was snapped off since I got it. I also hear this is adjustable. I can get one online for $9 and was wondering how you change it or adjust it?
Twinz
Re: How to replace the fin above the prop.
There is a cap above the "fin" on the outdrive. Pop this off and insert a socket (not sure what size) and off it comes.
Aviator5
Not socket, but allen wrench.
ErieRon
Directly above the "fin" (or trim tab) there is a hole in the outdrive (sometimes has a plastic cap in it). Down inside that hole is a socket head cap screw. You need an allen wrench (can't remember the size 5/16 or 3/8 maybe) to loosen the screw then the trim tab can be removed. It's usually corroded a bit, so you may have to tap it some...be gentle though:rolleyes: It's used to counter the torque from the prop rotation and is adjustable.
ziggy
on my old drive. the bolt drive is a hex wrench. allen wrench, whatever ya wanna call it. it drives a cap screw.. size. ? 3/8"? can't remember..
i agree with er. that bolt will corrode in place. i use a little pb blaster on it prior to trying to remove it..
Fordiesel69
Thanks, I would have never guessed it.
My symptom is horrible tracking at slow no wake speeds. I have to constantly over correct the steering as it wants to drift side to side. Once powered up, it feels fine. I was told a new fin will fix this.
Knightgang
Yep, they are right. All outdrives have them in some form. On outboards, they are bolted from underneath.
Maclin
That is low speed wander and is typical of sterndrive boats. That fin has little effect at no wake speeds, it is there to offset the thrust of the prop during take off and higher speed cruising to keep it tracking straight. I am not saying you do not need one but I think you will be disappointed in this regard.
Aviator5
It is also a sacrificial anode to protect your outdrive from corrosion.
Bart Sr.
Making smaller corrections reduces the wander.After more practice it will be second nature.By the middle of my first full season it was easy.
Glastron_V210
Check your steering also....have someone inside the boat turn the wheel while you hold the outdrive....any slop?
If not it's just deep v wander, perfectly normal and annoying.
C
Fordiesel69
That sucks, I just went to put it on and found that the PO broke it off for a good reason. The prop HITS!!!!!!!
Can I just grind a section out so the prop clears? If so how much space do I need?
sdoomaha
They make a smaller one for performance props. I had to switch mine over to the smaller one when I put on a cleaver prop. Rather than making fit, you might be better off taking it back and getting the proper one.
Take care,
Dshow
If you have power steering, it may not have a fin at all. Mine is flat.
Rocky_Road
Some people file (grind) enough for clearance...I used this one from Mercruiser:
cr2k
I have found that the wonder goes back and forth the same amount.
At least on my Regal. So I just set it to the center of where I am headed and let it go back and forth. Sure saves arm and wrist pump from fighting it.
And yes you can grind/file it to clear your prop. I would give it 3/8 to 1/2 in. clearance. More toward 1/2 if you have a rubber hub prop.
Some have 1/2 in bolt, some have 5/16 or 3/8 allen head, depends on year and model.
ziggy
ditto. i've even read it in a merc. s/m somewhere. can't remember where. maybe #6..
mine hit too. heres how my grind job turned out.
i've had zero issues from the grind and the prop is just what my rig needed. hope yours turns out as well..
rebars1
I had to do that on mine , too. Make sure you round off the front edge and keep it smooth.
mcleaves
My Volvo SX doesn't have a trim fin and I didn't think most outdrives with power steering did.
+1..
Pretty sure the fins are only for non-power steering applications
Don has a good picture of what angle to set the fin to counter the rotation of the prop and if the boat is pulling.
