Re: How to repair ladder mount
Several things, work with small batches of resin 2 to 4 oz resin for the job you are doing. much more than that and it will get hard before you are done working with it. Here is a catalizing chart for Polyester resins:
http://www.fgci.com/howto/ht005catalyst_chart.html
You need to cement the new piece of wood to the existing fiberglass. That means totally clean the area, sand the wood on all sides and the existing figerglass with coarse, 80 grit paper. Clean with acetone. Use a medium set epoxy to glue the wood in place.
To hold the wood in place you might consider marking and drilling the mounting holes for the ladder and using WAXED bolts to clamp the wood in place while the epoxy sets up. If you don't use the bolt holes make sure to seal the holes on the outside with duct tape so the epoxy doesn't leak all over your gelcoat.
You also need to prevent this from happening again because if water gets back up those holes it will start to rot the wood all over again. Once you have the new wood cemented in place, you can remove the bolts and coat the bolt holes with epoxy to seal them. This is not a 100% cure for the water problem. The best method is to go to good ACE/TRUE VALUE hardware or hobby shop that sells K & S tubing..
buy a piece of tubing with an ID size that is two to three sizes bigger than your bolts.. but is still a common drill bit size on the OD..
Bore holes thru the fiberglass and wood and install the tube all the way thru the hole, coat the outside of the tube with epoxy before you install the tube, you want to cement it in place and seal it and the wood you just punched a hole in.
As you install the bolts, shoot caulk/silcone in the tube in between the bolt and the tube to water seal 'the hole in the boat'
the tube isolates/seals/protects from water infusion and isolates it from EVER soakin' into the side walls of your new wood. Kind of like making a drain plug hole but for the motor mounts or any other holes in the transom."
Once the wood is in place and setup, fill the gaps around the edges of the wood with a type of filler that matches the resin type you are going to use. If your using polyester - fiberglass resin, use a polyester based filler. If you are using epoxy to glass this in use an epoxy based filler. If you don't fill in the edges, all of your resin is going to run out of the clothe or mat into the gap and you will have a 'dry' layup.
If you want to use Epoxy to glass in the repair, you can only use fiberglass cloth. Fiberglass matt has a binder in it that only desolves in contact with polyester resin and not epoxy, so the mat will remain stiff and you won't be able to form it. (yes, there are special epoxy mats available, but you probably don't have time to order them)
Because this job is small enought I would suggest using epoxy only and use several layers of fiberglass cloth on the inside. Depending on the thickness of the resin you are using you can either put the cloth down 1st and pour the resin on top, or coat the wood and then put the cloth on top of it.
I used polyester resin and it is generaly thinner than epoxy so I could put the clothe down 1st and pour the resin on top. I thought that let me position the cloth better. you will need a squeege or trowel to spread the resin around and work the bubbles out and a natural bristle, chip, brush is real handy.
Use a resperator with organic filter cartridges on it, both epoxy and poly smell and the fumes they give off will cause brain damage over time..
The checkerboard wood pattern, I dont' know about. Its possible that those are blocks that were glued up in alternating grain directions for increased strength.
I've said, enough now go get to work..
