how to remove water pump housing omc stringer electric shift
endurance
Like help removing water pump housing on omc electric shift thanks. Want to put new one thanks
Redrig
Master Chief Petty Officer
Re: how to remove water pump housing omc stringer electric shift
basically, you have to remove the outdrive.
seperate the lower and upper units.
once you have that done there are 4 bolts in the bottom of the upper gearcase that hold the unit in. remove them 4 bolts and you are in business.
I did this last year and it is not too bad, however you should definately have a manual to walk you through it all
