I am trying to remove the lower gear case on a Nissan 5 hp, NS5B. I removed two bolts (a small one and a larger one) and loosened the coupler that holds the two shift levers together and tried prying the gear case from the drive shaft housing with screw drivers and tried pounding it down with a mallet, but it won't come down. It swivels a few degrees side to side but won't come down at all. My Clymer manual doesn't list a 5 hp but mentions something about removing a spring pin from the shift rod with a punch. My manual shows a spring pin going through a clutch cam but I don't see any way to get at it.
Any ideas would be much appreciated!
