How to lift the top cap off?
twintrades
Just have a question I have a larson 16 ft open bow. I was going to lift the top section off useing a pully system/winch set up. Could i use the tie down areas to lift or would i break the glass around them ? Thought of roping them with slip knots and having the ropes go to 2 landscpae timbers crosswise and they would be linked to the pullys so i could lift straight up. ??
Is ther an easyer way ? I cant just lift a little and slide a board under. The front seating area goes straight down and is the same peice as the cap.
Help ? ? ?
redfury
Re: How to lift the top cap off?
I lifted my cap, but I wouldn't suggest using the tie downs. They are not strong enough to handle that amount of weight...no way. What I did was used straps and lifted it that way. You can check it out in my links. They are the left over tails from an old boat cover that I stitched loops into and ran a mini clevis through each and then onto a pulley. I used 10 pulleys to lift my top, and it's definitely the heavier portion of the boat, or at least equal to the hull.
oops!
agreed.
10 pullys is a lot but it cam be done with one and a few buddys around to help take the weight......
Bob_VT
Friends + beverages have to be cheaper than pulleys ;)
Rickairmedic
Twintrades what part of the country are you in . I have an 18' larson and theres no way I would try to pull the cap off it but might be willing to help with yours :D. I also have a 16' crestliner that I may pull the cap off of but it isnt an open bow.
Rick
redfury
agreed.
The pulleys only cost me about 2 cases of Corona ;). The nice thing is, I can lift the cap any time I want to :p
