How to jump start?
At the cottage, water access only, lost the boat keys!
Could someone tell me how to jump start this?
62cruiserinc
The B terminal is connected to the battery, the I terminal to the ignition, and the S terminal to the starter.
Connect a jumper from B to I, this will keep the boat running once it starts.
Then touch a jumper from B to S until the engine starts, then remove the jumper as soon as it starts running.
Then buy a new ignition switch ASAP, they are not expensive.
Steve
Thank you! Thank you!
Ill search for the keys some more before buying a new ignition.
The bad thing is that I’m no longer stuck at the cottage!!!!
stonyloam
Yeah, you also can go by color code. Red is +12 v from battery, purple is ignition and yellow red is start. Red to purple to run, touch red to y/r to start.
