How to find cid?
Blinkin
I have a 1980 175hp evinrude v6 crossflow and I am trying to find the cid. The crankshaft broke in two just below the flywheel and I found a v6 crossflow crankshaft from an 83(?) 150hp engine. The 150 is a 149cid and I am trying to find out if mine is a 149cid as well and if the crankshaft will interchange with it.
Any help from the all wise in this area is greatly appreciated.
Chinewalker
Re: How to find cid?
Both motors use the 388306 crankshaft... Same displacement.
- Scott
dajohnson53
Another way to check is to go to the brp.com website, use the parts search for both engines and compare the part number for that particular part from the two engines.
