Re: how to dry out the foam
If you use pour foam read the instructions thoroughly and carefully first. They will tell you how much it takes to make one cubic foot of foam. Then you need to figure out how many cubic feet you need. Of course the other way is just to mix it up and pour it in and see how much it foams up. That is how most people screw up when using this stuff. Many people think pour foam is easy to use. Just mix it in a bucket and pour it in. But it is subject to a lot of variable. It use what is called an exothermic reaction. When you mix the two parts they generate heat which makes the stuff foam up. If it gets too hot it foams too rapidly and breaks the little bubbles (the cells) and is no longer closed cell foam. It will absorb water. If it doesn't get hot enough it doesn't foam and makes what looks like cow pies or bread dough. It is also sensitive to ambient temperature and humidity, and dirt. Make sure you mix it in a clean container. If you do it right according to the manufacturers instructions you get nice 2 lb density foam.
This is why I advocate using block foam. Yes, it is hard to cut the blocks to fit the shape of a tri hull. And it is hard to find polyurethane foam in block. So I just use polystyrene. No it's not styrofoam. But I encase the foam in a polyvinyl bag or in fiberglass and epoxy so nothing can get to it. The problem with polystyrene is it will be attacked by gasoline, oils, bilge cleaners, just about any petroleum or caustic substance. Polyurethanes aren't attacked by these. So if you use polystyrene you have to protect them. Polyvinyl plastic sheet, which you can buy anywhere, isn't affected by these. Epoxy won't even stick to it. See here how I did it on my Sea Ray.
New Boatbuilders Home Page - Projects - 1972 Sea Ray 190 Rebirth You can buy this stuff in 2 foot by 8 foot sheets at any Home Depot or Lowes in 2 inch or 4 inch thick. One sheet of the 2 inch is 2.25 cubic feet. It is either pink or blue depending on the brand. I have seen it in white.
They also sell styrofoam sheets so be careful. The difference is styrofoam has much bigger cells, so it is not as dense, and it is easily damaged and tends to break down rapidly into those very familiar little white balls we all see floating in the water. It has it's uses but it is not as good as the polystyrene (some will say styrofoam is polystyrene. Yes it is but it's a brand name like Xerox, and made differently whereas polystyrene is the substance it's made of and a generic term)
