How to do a compression test
trucker28
I just try the compression test on my 18 hp johnson and was not sure if I did it right I pulled the cord once and got 60 psi pulled it 2 more times and got 90 psi on both plugs is this the right way to do it and is 90 psi good or bad thanks
R.Johnson
Re: How to do a compression test
Depending on how hard, or fast your pulling, four, or five pulls' should give you maximum reading.
jonesg
90 psi ain't real great and its not real bad either, have you tried running it?
Try some seafoam to decarb the rings? That usually brings it up a bit.
My compression jumped more than 10psi just from spraying seafoam on the pistons, let it soak then ran it.
crb478
90 psi on a 18 hp is not all that bad and being even in the most important thing. Most gauges read differently anyway unless they have been calibrated. To do the test pull both plugs out and then put the cord until you get the highest reading. Then do the other cylinder and compare the numbers. It sounds like your compression is fine to me. now you will need verify spark, them fuel. If you have all that and the timing is right it should run.
R.Johnson
90 lbs. on that older 18 is not bad at all, certainly nothing to worry about.
Gary H NC
Do the test with the throttle wide open and engine warm to get the most accurate reading...
F_R
The throttle does not have to be wide open, but I'm tired of explaining why. Nobody believes me anyway. Go ahead and open it.
trucker28
Ok compression test done I got it at 95psi now and got the motor running to just wanted to say thanks
thunnus69
ok, I'm one of those guys that asks the dumb questions. So why is it that you don't need to open the throttle??
freddyray21
in order to have compression the intake and exhaust have to be closed off. If the intake is closed off then it makes no difference if the carb is wide open or not.
F_R
OK one last time. A two stroke is different than a four stroke. The confusion comes because a four stroke needs an open throttle because the air is sucked into the cylinders. On a two stroke it is blown into the cylinders. Now read on before you jump at me.
On a two stroke engine, when the piston is on it's upstroke, air is drawn into the crankcase (thru the carburetor). On the downstroke, the air in the crankcase is compressed. When the piston reaches near the bottom of the stroke, it uncovers the intake and exhaust ports in the side of the cylinder. When that occurs, the compressed air in the crankcase blows through the intake ports, into the cylinder, and out the exhaust ports. When it is running, that flushing action is what clears the exhaust out of the cylinder and fills it with fresh fuel/air for the next stroke. True, there is a certain amount of back pressure from the exhaust when it is running.
But we are talking about checking compression at cranking speed, not running. When the piston is at the bottom of the stroke, the above flushing has occured. The air pressure within the cylinder is the same as atmospheric pressure outside. It makes absolutely no difference if the throttle is open or not, it is atmospheric pressure. As the piston continues on thru the compression stroke, first the ports are closed, then compression takes place. It is compressing from atmospheric to whatever the final result will be. That is what you are measuring--the difference between atmospheric and the final number.
One last, important thing: A two-stroke cannot run unless the above actions are taking place. It MUST draw in air to be compressed in the crankcase. It is true that the throttle restricts that air, but it does not block it off completely. If you look at the throttle plate, it has holes in it to admit some air, even if it is closed. That "some air" gets compressed in the crankcase and is blown into the cylinders, through the ports. Unlike a four-stroke where there would be a partial vacuum on the intake cycle, the two stroke never sees a vacuum in the cylinder. Again, it cannot run unless it has that compressed air in the crankcase. Even the "some air" from a closed throttle gets compressed in the crankcase and blown into the cylinder and out the exhaust, resulting in atmospheric pressure at that moment in time (cranking speed).
Hope this clears it up once and for all, but it won't.
mhg
OK
I see your reason for this, But, one of the reasons to open the throttles is the same as removing all the plugs while doing the test
the resritiction, as small as it may be, will slow the spinning speed of the engine
you should remove any restiction to air flow as possible
once the piston has sealed the chamber and started the compression it is also creating a vacuum in the cranckcase
with the carbs at wot there will be just a little less restriction to the air flow
M.
Mas
Yes, nice explanation FR! Maybe you can save your explanation and then "cut and paste" it next time someone asks...instead of retyping.
MAS
