scoutabout
Thread starter- Joined
- Oct 14, 2006
- 1,568
Looking for some advice. We recently installed a marine railway to pull the boat out of the lake. Problem is that once I have the boat secured to the cradle to come up I then have to climb over the bow and tight-rope walk up the rails to the switch at the winch. It's quite the pain in the rear.
Can anyone explain how I could wire up a remote that would work with the setup pictured here? The switch in the gray box is spring-loaded. Hold it off centre one way and the cable unwinds; hold it off centre the other way and it retracts; release in either position and it snaps to the off position.
The electric motor is 1 hp and plugs into a regular 110 AC outdoor GFCI. It also has its own breaker inline. Belt driven gearbox is a 50:1 reduction.
Wiring ain't my strong suit so don't be afraid to use little words and big pictures!
