how to change thermostat??
merkdawg0084
hey guys, 1984 evinrude 9.9. got everything put together on this motor. In my rush to get it done i forgot all about changing thermostat, Now that its together how in the HECK can i change that thermostat without removing powerhead?? Thanks
flyingscott
You will need a box wrench to get those off. I have gotten those out with out pulling the head. I use 2 putty knives to push the spring in then you can pull the water jacket straight out. But it is tricky and clearances can be a problem
