how to bleed and fill trim the right way
pinmonkey01
does anyone know the proper way to bleed and fill the trim and tilt i am new the the boat thing
roscoe
Re: how to bleed and fill trim the right way
It all depends on the make model and year of the motor we are talking about.
roscoe
In general:
If the trim pump is located next to the motor transom bracket, you lower the motor and remove the cap, fill the reservoir, replace cap, cycle up and down a few times. Repeat as needed to remove all air.
If the trim pump is located between the transom brackets, you raise the motor to fill the fluid, then do as listed above.
