Eddie Rivera
- Feb 19, 2013
- 183
Just completed the power head swap from my 1989 50hp 507X9B to my 1991 50 hp 508F91C. It's ready to be started how ever I see that my tower shaft has everything out of adjustment and I don't feel comfortable starting it this way.
1) spark control/timing link seems too short.
2) top idle or fill screw is not touching.
3) shift arm at tower shaft don't quite line up.
4) when I pull the control box lever out for neutral start, it feels too loose and doesn't really push on throttle roller.
5) when I shift to reverse, it seems to stay in and out of gear and neutral.
6) at wot, the butterfly is not fully opened or flat, it has like 1/4 more to go.
Note:
I'm using tower shaft that came with power head. Its a 91 carbie. When I installed it the throttle cam was a bit more than 1/4 inch away from roller and the line was up above it. Shift arm wasn't really staying in the center of the interlock switch.
Adjustments I did:
I stretched out the throttle link to close the gap. I adjusted the throttle roller. I stretched out the shift cable and the throttle cable.
I don't want to cause any damage by a premature or anxious start. I got the manuals but I don't fully get it and I'm too frustrated and exhausted and feel a brain block. I need to be explained like a 5 year old, could anyone be merciful, patient and help me??? I've included pictures. And will not move a finger till I hear from you guys to prevent more of my dumb mistakes.
Note:
Adjustments I did:
