How often do you grease trailer bearings?
agallant80
How often do you grease trailer bearings? I have Zurk fittings. How often should I give them a squirt or grease?
oldjeep
Re: How often do you grease trailer bearings?
You'll get all sorts of answers to this one. My answer - I repack the bearings once every 2 years and only use the through hub zirk to do the initial full pack of the hub - then I never touch it again.
emilsr
Same here on greased bearings. Every 2 years, clean/repack the bearings and replace the seals. Every other maintenance cycle (or so) I went ahead and replaced the bearings, but they will last longer than that so long as they're cared for.
Oil bath hubs require an oil change about every 7 years and little else. Virtually no maintenance. I don't want to go back to using grease.
....just in case you were considering an "upgrade" :lol:
Starcraft5834
If your "Zerking", remember to jack up the tire and spin it while pumping,,,
satanclause
I just grease when i change bearings, every 20 year or so.
The trick is to keep the Wheel center and bearings abowe the water :)
JaseBosto
I never grease mine,,.....I have oil bath....:laugh:
agallant80
So can someone tell me more about these oil bath things? My trailer goes between salt and fresh water.
JaseBosto
essentially it is a cap that is where your greese fitting is. The cap is clear. There is oil in there lubricating the bearings. It has a plug to drain and fill it. lgufp_gold_cutaway_1.jpg
colbyt
Master Chief Petty Officer
You come on over here and show me how to do that on these shallow ramps we have. :)
dingbat
When they need it.
Bearing housings are "sealed" assemblies. If you need to add grease between bearing changes, you have seal issues that need addressed.
Oil hubs work well until.........your oil seal fails while you are at highway speed, you can have a total loss of lubricant very quickly, burn up your bearings, ruin the hub, the axle, or both. You probably will not notice you have a problem until you see smoke. If your luck is really bad you may have a hub/wheel assembly come off while going down the road.
emilsr
Sure, it could happen, in theory, but has it? Do you have any data you can share? Why would a seal all of a sudden fail?
Over the road trucks have been using these things for years. Usually I'm the LAST guy to buy into new technology (still don't own an ipod), but in this case I think it's an option worth considering.
JimS123
Full roller tilt trailer. I check my bearings annually, but haven't packed them since 1986 (the year I bought it).
SWD
ipod???? Whats one of those????
satanclause
Swedish Viking here, think my first task would be to show you how a proper trailer should be constructed.
With one of those you wont need to back the trailer down so you drown the bearings.
I have my boat on a standard trailer with flip. That works better then most US trailers i seen.
I have mounted 2 145x45 mm wodden beams with rollers between them, the rollers lie 10mm lower then the beams so the keel go between them. Then when boat is up on trailer i just lift the front and kick in 2 car tires,and strap the boat down. Easy as hell to launch and take out.
Just get me a plane ticket and somewere to sleep and a sixpack and i come over and get you into year 2013 ;-)
/Thomas
