craze1cars
- Dec 26, 2004
- 1,822
Hello,
Have a 1999 Volvo 5.0L GL PWTR. Vortec 305 rated at 220 hp. All stock, currently fitted with the factory Holley 2bbl 500 cfm. Runs excellent, and at WOT I'm sitting at 4,600 on digital tach. I would like to inch this figure up to 4,800 for absolute max thrust out of the hole for our primary use: Watersports.
#1) I'm certainly considering the obvious option...drop an inch of pitch. But for a replacement 20p for the 4 blade stainless 21p like I have now, I'm looking at $400-ish. Or I can have mine repitched for probably about half that. Or sell mine and recover at least half. So no matter how I slice it, for dropping an inch I figure on $200-ish.
#2) Considering a second option...try a 600 CFM Holley 4160 or 600 cfm Edelbrock 4109 4bbl marine carburetor. Should be direct bolt-on if I pull the adaptor off my manifold, correct?? I know how to rebuild them and I know how to tune them....so I could snag a used one all day long for $150-ish and rebuild it like new. ESPECIALLY the Holley...I have complete jet tuning kit, several gaskets and other parts for that in my shop already. So I'm figuring for the same $200-ish out of pocket I would gain a few ponies that might allow the motor push my current prop to the extra 200 or 300 RPM's up top that I'm seeking?
Option #2 sounds very appealing because price is about the same, my current stainless 4 blade prop is absolutely spotless so I don't need to replace, AND I'd have the bonus of having picked up a few extra HP. I don't care much about extra fuel consumption.
BUT, do you have any thoughts on whether #2 is a realistic expectation? I'm not expecting miracles, and I realize that a 305 wil only flow so much air at sub-5000 RPM no matter HOW big the carb is. But is 200-ish RPM a realistic gain to expect? Or do you think I'd see more, less, or no change? And before anyone suggests it, I fully realize a 350 would bolt right up, but that costs a bit more than the $200 options I'm listing, so no thanks...
So I guess my biggest questions are these: How many real HP, and/or how many RPM's, would you folks expect I might gain by installing a properly tuned 600cfm 4bbl over my currently well-tuned 500 cfm 2bbl? Anyone by chance have results to share after doing this to a 5.0 Vortec? Mercruiser or Volvo? Thanks in advance...
