How much grease do you put in your hubs?
  • Total voters
    85
scooper77515
Re: How much grease do you put in your hubs?
Good article. Thank for the update. It goes along with my theory of bearings and grease.
bruceb58
Did you happen to notice it was written by jeffnick? The blog leaves out one important fact, that according to the Bearing Buddy instructions, you fill the hub entirely with grease and the blog assumes that isn't done. I do agree that if the hub is actually filled with grease that you should seldom, if ever, need to be pumping in more grease.
jeffnick
That's my point, if the hub is full as directed and like you say, it shouldn't need more grease, then why use the bearing buddy?
bruceb58
To keep a slight positive pressure is the theory.
bgc
Ensign
567 miles this weekend with the Bearing Buddy's stuffed full......
eddyjas
Only a small amount which is needed bu used trailers hub is necessary , it is about 1/4 of that you had used.
catfishcarl99
i have had my boat and trailer since 04. BB on it. i check them a couple times a season and add grease if there 1/2 way in. ive traveled from illinois to WV and arkansas a few times. ive never checked the temps never opened them up and never had any issues. if it isnt broke i aint fixing it.
scooper77515
It appears that the old saying "a little grease is better than NO grease" is appropriate here. And furthermore, MORE grease is better than LOTS of grease!!!
