How much charge should my engine be outputting
egscharf
I have a 1994 112HP with the 9 amp stator. How much charge should it be putting out? I'd imagine it would depend on rpm's, correct?
Vic.S
Re: How much charge should my engine be outputting
9 amps is the maximum rating but the actual current will depend on the state of charge of the battery and what equipment is switched on.
It wont "output" more than the system demands so with a fully charged battery in good condition and no electrical equipment in use the current will be quite low.
Yes it will vary with revs but I believe you have a rectifier /regulator with that stator so that will control it once you reach a certain point.
