after reading the endless threads here about props to tweak top speeds I was wondering just how much room is there for changing you boats attitude with a new prop?
I have a jon boat with the recommended prop that came with it and it runs the recommended rpms but seams a little on the slow side for speed.
it would stand straight up on take off (literally the transom was within an inch of going under)
I always "assumed" the recommended prop listed for my motor was right and only finding the pitch was needed but it looks like there is a whole lot more to picking a prop then just whats listed for your motor so how much room is there a way to get more speed out of it and change how it acts?
EDIT:
its a Suzuki df40 on a 15 ft flatboat with this dealer recommended prop on it:
POWER TECH SRD3 PROPELLER 11.25" DIAMETER, 13 PITCH, 3 BLADES, RIGHT-HAND ROTATION, BEST ALL PURPOSE, SS PROP, 20 DEGREES RAKE - POLISHED FINISH ONLY
It can be seen here: http://www.ptprop.com/index.php?pag...facturer_id=0&option=com_virtuemart&Itemid=46
EDIT:
