Jerry_NJ
Thread starter- Joined
- Aug 23, 2010
- 250
I have a 9.9 HP and I am not sure the engine is getting proper cooling.
I have ran it for short times in a lake with water temps around 60 degrees and find when I remove the engine cowling I can touch the engine block and even the heads and they do not feel hot. Does this mean/prove the engine is getting reasonable cooling, at least not over heating?
Is there a better method to test beyond seeing the pilot (pee) hole flow of water?
