How does a OMC 5.7L Stringer Trim/tilt
BowTieGuy
Ok so I am in the middle of swapping my broken 3.0 OMC engine for a 5.7. On the old engine there was a bracket on the front of the motor with a rotating shaft that would raise and lower the engine and intermediate drive for the trim. My new engine did not come with this setup so I am stuck on how to get my new engine (5.7) to go up and down so i can trim the boat.
I originally hard mounted the engine thinking i could use the tilt motor to trim it, but I have been told that wont work. Can someone please tell me how the 350's trim and send me some pictures? i cant find any information on this. If i cant find the 350 parts, i will just fab up my own bracket with the old 3.0 stuff. Thanks for the help!
oldsub86
Re: How does a OMC 5.7L Stringer Trim/tilt
I think you need to find a trim setup for the V8 which will be similar to what you had on the 4 cylinder.
Might be easier to add trim tabs on the boat.
Randy
Howard Sterndrive
the V6 and some V8's used a hydraulic trim system, where the front engine mounts are actually hydraulic trim cylinders. Some V8's used a big "saddle" type front engine mount that had a mechanical worm affair like the 3.0
BowTieGuy
So how big of trim tabs should I get? Should I get single or dual actuator ones? They say a 12x9 tab should work for boats 20-22 feet. Mine is a 19' but I dont have any tilt so should I get larger ones?
Howard Sterndrive
Nauticus SX Smart Tabs - they're on sale here at iboats right now.
BowTieGuy
Sweet! Thanks for pointing that out!
I also want to get a new water pump impeller kit. How do I tell which lower unit I have? Where are the ID numbers at? I see here on iBoats that there is a few different selections and I dont know which one I need. Can anyone help?
