how do you remove omc king cobra drive from boat?
Don S
Re: how do you remove omc king cobra drive from boat?
Disconnect the aft trim rams, remove the 6 retaining nuts holding drive to pivot housing and pull the drive off.
muc
"Retired" Association of Marine Technicians...
If it’s a cone clutch king cobra.
You need to remove the shift cable pin after the drive has slid back about 1 inch.
There is an o-ring that seals the shift cable cavity that some mechanics like to replace.
