Re: How do you install a new Volvo water connection housing?
Just wanted to agree with P.P.40 regarding pulling the gear box.
Removing and inspecting the gearbox, ujoints, bellows, etc is an annual part of maintaining your outdrive. Once you've done it the first time, is quick and easy the next.
Be sure to replace all the two orings and get some perfect seal or Permatex aviation gasket sealant, I use this on everything.
With the gear box off replacing the hose connection is a snap.
BTW, I've replaced my hose connection and gasket twice without removing the gear box and found it to be fairly easy. However my outdrive has no corrosion and is not exactly the same as yours.
why are you replacing the fitting to begin with?
