The rubber handle, remove the metal insert and then unthread the line.
You might use a pair of vice grips to hold the line so it doesn't unwind on the spool.
There should be a plastic cover over the metal insert or bar holding the line that you just pop out.I always tie a slip knot in the line to keep it from disappearing down the rabbit hole.
