How do tell if motor is overheating?
roger56
59 Johnson FD13R Last time I had this motor runnung it seemed to get very hot? What do I need to look for as a problem with it getting to hot. Lot of smoke too. I was rebuilding the carb which is done. Now I have an electrical problem I hope to correct tomm. If motor is running hot I do not want to do any damage.
How hot do these motors get under normal operation?
Re: How do tell if motor is overheating?
If you can't put your hand on the head for more than just a couple seconds it is overheating. Otherwise there are wax temperature stick that melt at a specific temperature. Or you can use an infrared temp gun.
roger56
If it is over heating does this mean there is something not working properly in the lower unit to cool the engine ?(Impeller?) I have never worked on a lower unit of a motor Is it difficult to repair. Can I do it myself?
