Re: How do I?
Are you sure the carb is flooding from a carb problem or a fuel pump problem. Check the clear hose going from the fuel pumpt to the carb for gas, if it has gas in it, the fuel pump is bad.
If the hose is dry, you could have a choke that is too tight which would make it flood out.
Or the needle and seat could be sticking open, or it may be way out of adjustment with the idle mixture screw.
Could you explain why you think it's flooding, and when?
