How do I replace or repair my exhaust riser? 5.0FL PMDA
Michigan Jason
I have a 5.0FL pmda 1995 ford engine. The starboard riser has a leak and spills warm water into the bilge when the engine is running. Mechanic said it is cracked at the bottom. How do remove it to see if I can jbweld the crack, or replace it?
alldodge
There are 4 long bolts which screw into the top of the manifold (see item 35 and 39).
Michigan Jason
Thank you for the reply AllDodge! Is there by any chance a link so the service manual for my motor? I know a couple years ago either Don or another kind gentleman had sent me a link with the pdf manual. I just cannot find where I saved it.
alldodge
There is a link but I'm not sure where on the 4shared site it is. That said the last time I tried to download one of DonS manuals from 4shared, my virus software stopped a some malware. So I no longer show folks to where his other files are. Better not to have the manual then have some kind of crud on your computer.
I think member bruceb58 has most of the manuals or at least might know where to get them
Sparkinator
These are links to an HU series. That is the drive I have in my 95. It's a Ford 5.0 FL as well. Probably not much difference at all.
Here's a link to your manuals, they are for the Volvo HU series.
http://www.4shared.com/office/YhKe25...anual_7788.htm
http://www.4shared.com/office/1rkePE...ve_7788851.htm
http://www.4shared.com/web/preview/pdf/eMAEnxXX
They are downloadable and printable (if you ever need to) pdf genuine Volvo manuals that explain pretty much anything you will need for your outdrive.
Ayuh,..... Don't even think about it,.....
When the riser leaks, yer motor is in grave danger,.... Hydro-lock, 'n a busted motor is only a heart beat away,....
Also, if the gasket surfaces 'tween the riser, 'n manifold is gettin' bad, Replace both the manifold, 'n riser,...
edit; the back story
