How do I Know What voltage reading My stator should be putting out
Bdavis0555
Hello again...I have a 1987 Suzuki DT 175 and my mechanic seems to think it has a bad "stator" or a bad "power pack" he told me to try and locate the stator high side and lowside voltage readings that the stator should be putting out...he hasn't tested them yet so im not sure what they are reading right now...the engine "boogs" down under a load...it seems to start just fine and I can rev it up using the "wammy bar" when its in nuetrel, but when I put it in drive, it it gets the boat up on a plane at about 10-15 mph and then it just boogs down..and It gives little spurts of power and it seems like it wants to take off but it doesn't ... does anyone know what the stator and power pack should be at if they were working correctly??? thanks again
Barnacle_Bill
Re: How do I Know What voltage reading My stator should be putting out
Check CDI's website for the readings you should get. You will need a DVA to read them properly.
Bdavis0555
THanks for the reply....where exactly do I find the cdi website???
