How do I get to the Midship bilge on 2302
drew2302
Hi, I have a 1995 2302, and I would like to change the Midship bilge pump on the boat. How do I get to it or better yet, Where is it ?
Thanks ,
Drew
frankie g
Re: How do I get to the Midship bilge on 2302
Mid ship? I have a 2004 2302 and there's one in the stern and one in the cabin under the step down, will that help?
springhead
this might help you.
ITEM PART PART DESCRIPTION U/M QTY.
NO. NUMBER
REVISED: 4-5-95 20 PUBLISHED: 6-10-94
2302 FT 1995
FRESH WATER SYSTEM - cont.
* 1392 HAND PUMP EA 1
MIDSHIP BILGE PUMP SYS
* 60249 AUTO FLOAT SWITCH EA 1
* 36656 SECONDARY OVERCURR.PROTECTION LABEL EA 1
19 61039 500 GPH BILGE PUMP EA 1
* 55609 SFTWL H2O HOSE 3/4" FT 7
* 708 THRU HULL PLAS 3/4" EA 1
SINK DRAIN SYSTEM
* 6272 SINK SINGLE W/RIM EA 1
* 57543 2" S/S SINK STRAINER EA 1
* 4790-E DRAIN ELBOW ONLY EA 1
* 57544 DRAIN SLIP NUT EA 1
* 57545 DRAIN WASHER EA 1
20 1115 SFTWL H2O HOSE 3/4"' FT 1
DECK DRAIN SYSTEM
* 8492 THRU-HULL,REV FLANGE 1 1/2" EA 4
* 58927 ADAPTER,FEMALE,NYLON 1.5" 90 DEG EA 4
* 1300 DRAIN HOSE 1.5" WHITE VINYL FT 11
* 11394 T-HULL FITTING,1.5"W/SCUPPER EA 2
* 708 THRU HULL PLAS 3/4" EA 2
21 1272 HOSE-3/4" ID X 1" OD FT 3
  • ~$Doc1.doc
drew2302
Okay thanks, now that I kinda have an idea where the bilge is,,
How do I get to the bilge to change it out ?
thanks
kfurlonger
Hi I can not open the file attached? I have a 1992 Hurricane Midship and I'm try to figure out the drain and water system can you help?
