so i've got my floor out, but because of the width of the plate on my circular saw i have about a 2-3" band of old, solid floor all the way around the perimeter of the interior of the hull (where the floor was glassed to the hull). this is also in close proximity to where the two planes of the hull intersect (see where arrow is pointing in image). because of this intersection, it's pretty tight in there.
my question is, if the remaining band of floor is solid, is there a way to fit the new floor into the opening i have and splice to this band. the inside edge where i cut is about 1" from the exposed hull with no stringer in this area, or should i grind this band out and glass a new hull all the way to the outer hull.
hope this is not too confusing, don't have any pics at this time.
